[GRASS5] which, less and SUBMITTING
Reinhard Brunzema
r.brunzema at web.de
Thu Apr 12 02:08:38 EDT 2001
Glynn Clements schrieb:
> Reinhard Brunzema wrote:
> > Linux users expect man running the 'less-way'.
> So what? The world does not revolve around Linux users, or their
> expectations.
Why do you metion it? Nobody said so.
Anyway, I don't see any advantage in disrespecting them or users of any
platform.
> Having said that, I do agree that programs shouldn't try to override
> system defaults. System environment variables (PAGER etc) should be
> left alone; i.e. if PAGER is unset, it should be left unset (which
> should cause "man" to use whatever pager is specified in
> "man.config").
I agree.
> If it's too much effort to make GRASS' code handle the case where no
> pager is specified (e.g. if lots of files use something like
> popen("$PAGER")), the simplest fix is to use a different environment
> variable (e.g. GRASS_PAGER) within GRASS. The startup could then
> ensure that this is set to something whilst leaving PAGER alone.
If that's a solution, it's okay with me.
> > When they want the old and common behavior of the man pages back, they
> > have to do a lot of work. I don't mean adding PAGER=less in a
> > configuration file - I mean finding out, what they have to do. You have
> > to be a unix/linux expert or at least a advanced user to know that PAGER
> > is related to man.
> Well, you have to be capable of reading the man(1) manpage.
YES! (Remember, you wanted to read a GRASS-manpage, not the man manpage)
> It's a
> pretty sad state of affairs when that is considered the preserve of
> "advanced" users.
Sad or not, it's the truth. Keep in mind, not everybody has a system
supporting his native language. There are a lot of options, variables
and files that rule the behavior of man, in the worst case you have to
check all of them.
> > In general I think, a program should keep as much work away from the
> > user as possible.
> That doesn't mean it should do things that aren't its responsibility;
> that way lies needless complexity, which only makes the program harder
> to understand and its behaviour less predictable.
As you mentioned before, this has already happened, the trouble is
already there, because we have an unexpected behavior.
> > > This would allow individual customization of the pager, which is in my
> > > eyes the purpose of the GRASS initialization setup. The code in init.sh
> > > is IMHO only providing a fallback in case no PAGER variable is set.
> > The new code wouldn't change that behavior. It's just a better fallback.
> "Better" is subjective. "more" may be primitive, but it seldom fails
> horribly, as "less" often does if curses is broken, or if termcap or
> terminfo are broken[1], or if $TERM is incorrectly set[2].
You are in trouble anyway, in that case.
> Also, "less" moans about dumb terminals (ones which don't support
> cursor positioning),
We could use 'less -d', if this is really a major problem.
> and dumps loads of cruft into the output, which
> is a nuisance if you're capturing it (e.g. with "script") for later
> reference.
If you use such advanved features you are probably able to set up PAGER
the way you want without any trouble.
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
