[GRASS5] which, less and SUBMITTING
Reinhard Brunzema r.brunzema at web.de
Wed Apr 11 14:19:37 EDT 2001
Michel Wurtz schrieb:
> There is also a "whereis" command that can be used, or even the builtin
> type command (in all bourne compatible shell).  They don't allways give
> the same result, but type is IMHO a good solution too. Ex :
Markus pointed out, that even 'type' is not always available. And I
don't know anything about 'whereis'. It can be used on my linux system,
but what about the other supported platforms?
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
