[GRASS5] Files for subpackages
Silke Reimer silke at intevation.de
Mon Apr 9 07:48:19 EDT 2001
Hi Markus,
many thanks for your answer. But I still have some questions (see
below).
On Fri, Apr 06, 2001 at 04:26:42PM +0100, Markus Neteler wrote:
> Hi Silke,
> On Tue, Apr 03, 2001 at 02:09:32PM +0200, Silke Reimer wrote:
> > Hello everybody!
> > The last days I tried to build a RPM-package of Grass5. The aim was
> > to have three subpackages with respectivly NVIZ, postgreSQL and the
> > ODBC part of GRASS. When I wanted to specify the files of these
> > subpackages I was a little bit confused. I'd like to explain why:
> > Concerning the installed files it doesn't make any difference if
> > NVIZ or ODBC are included. Otherwise I think that at least the
> > ODBC-driver or nvwish should be installed as they are build by
> > gmake5.
> > Can somebody explain me this effect?
> actually I don't see the problem... What is the idea of separation?
> Generally: The basic package should have NVIZ compiled *without*
> PostgreSQL support, an additional NVIZ package *with* PostgreSQL support
> would be fine (to overwrite the other version). The ODBC doesn't hurt
> at all (I think so).
> Does this help?
Not really. Our idea was to have one subpackage with those parts of
grass which use OpenGL (which is NVIZ), another one for PostgreSQL
and a third one for ODBC. As I understand you a subpackage for NVIZ  is
not possible/desired. Why not? In my opinion it shouldn't be a
problem because NVIZ is build separatly by gmake5 and linked to
grass5 afterwards.
Second: Can you give me the reason why the ODBC doesn't hurt at all?
My initial problem still exists. I think I should explain it again
because my first explanation wasn't really precise. The problem is
that the list of files before the building and installation of NVIZ
doesn't differ to that afterwards. I solved the problem by looking
for those files which are build by gmake5 in the NVIZ-directory
and the NVIZ-documentation files. But I still think that it is curios
that a difference doesn't exist.
Many greetings
Silke
Intevation GmbH			(http://www.intevation.de)
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
