[GRASS5] 'unsubscribe grass5'
Tinus Joubert tinus at netbus.co.za
Wed Apr 4 09:17:34 EDT 2001
----- Original Message -----
From: "Markus Neteler" <neteler at geog.uni-hannover.de>
To: <grass5 at geog.uni-hannover.de>
Sent: Wednesday, April 04, 2001 10:46 AM
Subject: Re: [GRASS5] Arrow keys and default pager
> On Wed, Apr 04, 2001 at 03:04:42PM +0700, Justin Hickey wrote:
> > Hi Markus
> > Markus Neteler wrote:
> > > On Wed, Apr 04, 2001 at 08:15:26AM +0200, Andrea Aime wrote:
> > > > couldn't it be a default option if "less" is
> > > > available on the machine (at least under Linux)?
> > > I agree.
> > I disagree. I would like to avoid adding things into the initialization
> > code that are not strictly necessary. It is already complex. Since less
> > is not available on all platforms then it should not be the default. As
> > I said in my reply to Andrea, you should be able to set the PAGER
> > environment variable in your $HOME/.bashrc file.
> O.k., it has to be platform independent. I am still wondering why i.target
> and other modules behave so user unfriendly. Maybe it is a different
reason
> and not related to more?
> Is anyone there having GRASS 4.x and can try the i.target /list to report
if
> behaviour is different (and more convenient)?
> Thanks,
>  Markus
> If you want to unsubscribe from GRASS Development Team mailing list write
to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
If you want to unsubscribe from GRASS Development Team mailing list write to:
