[GRASS5] Re: [GRASS-CVS] CVS update: grass
Glynn Clements glynn.clements at virgin.net
Thu Aug 2 21:46:14 EDT 2001
Andreas Lange wrote:
> I can confirm that it does not work under Windows / cygwin either.
> Headers and libs are not found even if specified on command line.
Details (e.g. config.log) would be appreciated (actually, details are
necessary; I can't fix anything until I know what's wrong).
> Fix is urgently needed, as i'd like to build a new winGRASS test build.
Cygwin might take longer to get right than actual Unix systems; in the
meantime, you can just check out the previous version.
Glynn Clements <glynn.clements at virgin.net>
