[GRASS5] configure checks, fortran, static libraries
Eric G. Miller
egm2 at jps.net
Mon Aug 6 21:14:35 EDT 2001
On Mon, Aug 06, 2001 at 06:21:04PM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > PS: An idea for postgresql support: In case the postgres stuff is not found,
> > maybe the support should be switched off? Then the NVIZ can be compiled
> > straight forward, the user doesn't need to run configure again with
> > --enable-postgres=no. Just an idea...
> I've just noticed that USE_POSTGRES doesn't actually appear to be used
> anywhere. configure.in has AC_SUBST(USE_POSTGRES), but neither
> Makefile.in nor src/CMD/head/head.in reference it.
It was added with the idea that it would/could be used for modules with
providing postgresql functionality. I was asked to make postgres=yes,
the default. The NVIZ script/build hack should prevent building a
broken version (guess it doesn't ?).
Eric G. Miller <egm2 at jps.net>
