[GRASS5] Raster_int()
grass at geni.cemtlo.com
Wed Aug 8 04:57:52 EDT 2001
Hi developers,
I have a question about Raster() functions.
src/display/devices/lib/Raster_chr.c:
int
Raster_char (int num, int nrows, unsigned char *array, int withzeros, int
color_type)
i = num ;
while(i--)
*(iptr++) = *(cptr++) ;
in the above code segment, we can know that 'num' means the length of 'array'.
However,
src/display/devices/XDRIVER/XDRIVER24/Raster.c:
int
Raster_int(int num, int nrows, int *array, int withzeros, int color_type)
for (j = 0; j < num; j++) {
if (*arr == 0) {
if (width > 0) {
for (i = 0; i < nrows; i++) {
XPutImage(dpy, bkupmap, gc, grimage, 0, 0,
cur_x + start_col, cur_y + i, width, 1);
width = 0;
start_col = j + 1;
} else {
start_col++;
} else { /* non-zero pixel, put into the image */
if (get_table_type() == FLOAT) {
if ( color_type )
XPutPixel(grimage, width++, 0,
(u_long) _get_color_index(*arr));
else
(u_long) *arr);
} else if (use_visual->class >= TrueColor) {
arr++;
in XPutPixel() calls, we always put pixels in the same row 0.
And if some zero values found, XPutImage() duplicates this row 0 into row
1-(nrows-1).
Supposing this case:
/* image
00100
01010
10001
int *array = { 0, 0, 1, 0, 0,
0, 1, 0, 1, 0,
1, 0, 0, 0, 1};
CASE A)
'num' is ncols.
Raster_int(5, 3, array, 0, 1); /* num is width */
produces the following image:
00100
00100
00100
CASE B)
'num' is the number of array elements.
Now,
Raster_int(15, 3, array, 0, 1); /* num is the number of elements */
produces:
00100 01010 10001
00100 01010 10001
00100 01010 10001
CASE C)
So, we should use Raster_int() like the followings:
for(i=0; i<3; i++){
R_move_abs(x, y+i);
R_raster(5, 1, 0, array+5*i);
/* this func calls Raster_int(5, 1, array+5*i, 0, 1); */
produces:
00100
01010
10001
'nrows' should be always '1' to get a correct result. Why is this needed?
Is this intended?
It's so inconvenient and not easy to predict results.
All modules may be working on 'CASE C)'. I think that this behaviour might
be related to many G_* functions such as G_get_raster_row() which manipulate
raster maps row by row. G_get_raster_row() function reads raster map row
by row. Then we draw this row on a monitor. Then read again, ...
So we have not experienced any trouble drawing raster data.
I think that 'num' should be the number of colums and CASE A) should work
correctly.
Any good idea?
Regards,
Huidae Cho
