[GRASS5] WARNING: CVS broken
Jan-Oliver Wagner
jan at intevation.de
Fri Aug 10 08:51:51 EDT 2001
On Fri, Aug 10, 2001 at 12:23:38PM +0100, Glynn Clements wrote:
> Basically, the only way to make CVS "forget" something is to either
> restore the repository from a backup, or modify the repository
> directly (and I definitely wouldn't recommend the latter option).
Changes directly in the repository are the way to go in
such cases (it is even mentioned in documentation/manuals).
Some maintenance operations only could be done this way.
Of course, doing so means you must be extemely careful.
Jan
Jan-Oliver Wagner http://intevation.de/~jan/
Intevation GmbH http://intevation.de/
FreeGIS http://freegis.org/
