[GRASS5] WARNING: CVS broken
Glynn Clements
glynn.clements at virgin.net
Thu Aug 16 08:53:50 EDT 2001
Markus Neteler wrote:
> a big thanks to Bernhard and Glynn for their CVS investigation and cleanup.
> I have checked the cvs tree (releasebranch_11_april_2001_5_0), some/all
> problems seems to be cleaned up now.
> Still I don't fully understand why we have another branch
> now:
> releasebranch_14_august_2001_5_0_0
I created it so that there was a functional release branch. At the
time, I had no idea if or when the problem with the original branch
was going to be fixed.
> Does this make sense to have two release branches? And - shall we all check
> out this branch and work here?
> To reduce confusion I would prefer to continue on
As that appears to be working again, it may as well be used.
Glynn Clements <glynn.clements at virgin.net>
