[GRASS5] WARNING: CVS broken
Glynn Clements
glynn.clements at virgin.net
Thu Aug 16 15:59:46 EDT 2001
Markus Neteler wrote:
> > > 2001-08-08 23:09 frankw
> > > * html/html/r.in.gdal.html: added notes on null support
> > > Obviously this is not in CVS (and more). Where is it gone?
> > It is in the cvs in the main branch:
> > Check:
> > http://freegis.org/cgi-bin/viewcvs.cgi/grass/html/html/r.in.gdal.html
> > and
> > http://freegis.org/cgi-bin/viewcvs.cgi/grass/html/html/r.in.gdal.html.diff?r1=text&tr1=1.8.2.2&r2=text&tr2=1.9&diff_format=h
> > That is the good part of cvs: It rarely looses data at all
> > if it was checked in once.
> However, in this case Frank Warmerdam first checked into exp tree, then
> (after I realized that) into the release branch.
That's not what CVS says. The above log entry is for revision 1.9,
which is on the trunk:
revision 1.9
date: 2001/08/08 21:09:29; author: frankw; state: Exp; lines: +8 -0
The most recent commit on the release branch is:
revision 1.8.2.2
date: 2001/07/09 12:43:32; author: markus; state: Exp; lines: +3 -1
cosmetics
I get the same results for all four of the versions which I have
checked out: current version of releasebranch_11_april_2001_5_0, old
(pre-fix) version of releasebranch_11_april_2001_5_0,
releasebranch_14_august_2001_5_0_0, and the head.
Only the head version has the notes regarding null support.
Basically, if anything was committed during the period in which the
non-branch releasebranch_11_april_2001_5_0 tag existed, it's anyone's
guess as to the branch on which it ended up.
Glynn Clements <glynn.clements at virgin.net>
