[GRASS5] [bug #788] (grass) grass5 startup: local aliases not respected
Request Tracker
grass-bugs at intevation.de
Mon Aug 20 03:37:45 EDT 2001
this bug's URL: http://intevation.de/rt/webrt?serial_num=788
Subject: grass5 startup: local aliases not respected
grass downloaded at: CVS Server, Germany
grass sources source: yes, I am using the latest GRASS from CVS
When starting GRASS, aliases defined in $HOME/.bashrc are not
copied within the GRASS shell environment. I tried to fix that,
but obviously the shell type is changed on startup.
A fix would be welcome.
Markus
-------------------------------------------- Managed by Request Tracker
