[GRASS5] WARNING: CVS broken
Glynn Clements
glynn.clements at virgin.net
Mon Aug 20 16:36:34 EDT 2001
Markus Neteler wrote:
> Bernhard has
> "Removed irritating non-branch tag "releasebranch_11_april_2001_5_0_0".
> but I don't know how to check against this wrong tag.
You can't; the non-branch "april" tag has gone. Even if it were still
there, it wouldn't do you much good: AFAICT, everything which wasn't
part of the branch was tagged with the non-branch "april" tag.
> An error to start
> with is the html/r.in.gdal.html page which doesn't contain hints on NULL
> support which should be there.
If you wish to find changes which were inadvertently committed to the
head (e.g. html/html/r.in.gdal.html, version 1.9), check out the head
and use e.g.:
cvs log -d '>2001-08-09 00:00'
or
cvs diff -D '2001-08-09 00:00'
Glynn Clements <glynn.clements at virgin.net>
