[GRASS5] NVIZ: DRI acceleration running!
Markus Neteler neteler at itc.it
Wed Aug 22 11:26:12 EDT 2001
Hi there,
good news: the DRI acceleration is working now (at least here,
tested on different machines). Congrats to Roberto Flor.
The fix is in CVS, if you want to test:
 cvs up -dP src.contrib/GMSL/NVIZ2.2
 gmake5 -i src.contrib/GMSL/NVIZ2.2
Roberto has upgraded the togl.c to 1.5 (which was already living in
GMSL/NVIZ2.2/TOGL for amusement). The real fix was that the wrong
tkInt was included (fixed now). Even the original TOGL packages
contain this bug...
So - don't forget to activate DRI in /etc/X11/XF98config[-4].
The "gears" program or "glxinfo" will tell you about DRI running.
NVIZ is really FAST now.
Thanks to Roberto Flor from ITC-irst,
 Markus
On Wed, Aug 22, 2001 at 04:26:59PM +0200, grass at intevation.de wrote:
> Date:	Wednesday August 22, 2001 @ 14:26
> Author:	markus
> Update of /grassrepository/grass/src.contrib/GMSL/NVIZ2.2/src
> In directory doto:/tmp/cvs-serv5174
> Modified Files:
>       Tag: releasebranch_11_april_2001_5_0_0
> 	togl.c togl.h
> Added Files:
> 	tkInt.h tkInt4.0.h tkInt4.1.h tkInt4.2.h tkInt8.0p2.h
> 	tkWinInt.h
> Log Message:
> Roberto Flor <flor at itc.it>: upgraded to TOGL 1.5, fixed NVIZ crash with
> DRI and Xfree 4.0.3/4.1.0 by using the right tkInt file (wrong version was
> included)
> grass-commit mailing list
> grass-commit at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-commit
