[GRASS5] WARNING: CVS broken
Markus Neteler neteler at itc.it
Fri Aug 24 09:22:37 EDT 2001
On Thu, Aug 23, 2001 at 11:28:01PM +0100, Glynn Clements wrote:
> I'm fairly sure that the problems all started at some point on
> 2001-09-09, although it's conceivable that it occurred late on the
> 8th.
[2001-08-09]
> cvs log -d '>2001-09-08 00:00' should catch everything that might have
> been lost. Basically, you're looking for 2-part versions (1.x), which
> indicate that a commit was made to the trunk.
Thanks for looking into this. From checking
cvs log -d '>2001-08-09 00:00'
I receive the log. While looking at it, there are some 2-part versions
found, but they are immediately followed by a 3-part versions. This should
be o.k., see example below:
revision 1.1
date: 2001/08/23 12:28:23;  author: markus;  state: dead;
branches:  1.1.2;
file README.tcl was initially added on branch
releasebranch_11_april_2001_5_0_0.
revision 1.1.2.1
date: 2001/08/23 12:28:23;  author: markus;  state: Exp;  lines: +5 -0
added urls
So far I cannot detect any problem (I am still no specialist).
If anyone wants to look as well, the file is here:
 http://grass.itc.it/cvs_diff/
  -> cvslog_24_aug_2001.gz
Shall we declare the problem as solved?
Thanks,
 Markus
PS: just fixed ps.map which crashed on Redhat7.1.
