[GRASS5] [bug #867] (grass) v.out.sdts crashes
Eric G. Miller
egm2 at jps.net
Mon Dec 10 22:02:10 EST 2001
On Tue, 11 Dec 2001 02:26:58 +0100 (CET), Request Tracker <grass-bugs at intevation.de> wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=867
> Subject: v.out.sdts crashes
> Hi,
> it seems that v.out.sdts just crashes. Does anyone have a
> better experience? I having trying to export the "roads" map
> from Spearfish just to see if it is working.
It didn't crash on me, but...
1) It is outdated in it's handling of projections/datums.
It only supports lat/lon or UTM and only checks ellipsoid,
not datum.
2) It really requires the associated metadata routines to be
functional in order to produce "correct" output.
But, I was able to successfully export and reimport data with it...
Eric G. Miller <egm2 at jps.net>
