[GRASS5] Parameter names inconsistency - vector modules
    Markus Neteler
    neteler at itc.it
    Thu Dec 13 12:38:27 EST 2001
some vector modules show inconsistencies with parameter names.
As most of these parameters have been introduced recently (or
in a beta in 5.0)  I propose to correct that. Later, in 5.1
we will completely cleanup the parameter structure.
Here I am only thinking to clean "category number" and "category label"
which regularly leads to confusion when not named properly.
Examples:
d.area help
   category   List of area categories to display
 -> should be
   catnum     List of area category numbers to display
v.in.shape help
  attribute   Name of attribute to use as category
 -> should be
   catnum     Name of attribute to use as category number
d.vect.cats help
   cat   Vector category type to be displayed
 -> should be
   catnum     List of category numbers to display
Suggestion: The latter shall go into d.vect anyway (to be compliant with
d.rast and to reduce the number of modules).
If there are no objections, I will change above.
Like that it's too confusing in my opinion. Suggestions are
welcome of course!
Markus
