[GRASS5] dxf imports
Michel Wurtz mw at teledetection.fr
Mon Dec 17 02:09:45 EST 2001
"Roger S. Miller" wrote:
> The most well-developed GNU-licensed DXF import library I've found (DIME)
> apparently doesn't import text entities.  Currently I use a fairly simple
> program to extract text entities from a dxf file and store them in a paint
> labels file.  This process works very well if the paint labels are then
> used in ps.map.  It doesn't work well on the GRASS display; because
> paint.labels doesn't understand text rotation, transparent backgrounds
> and a number of other text features.
I think Grass lacks a "d.text" function, and probably a better support
for fonts. the best would be a support for TrueType fonts, usable on
both Unix and Windows.
Michel WURTZ - DIG - Maison de la télédétection
               500, rue J.F. Breton
               34093 MONTPELLIER Cedex 5
