[GRASS5] Re: [GRASSLIST:2833] core dumps after i.rectify
Markus Neteler neteler at itc.it
Mon Dec 31 08:09:26 EST 2001
On Mon, Dec 31, 2001 at 11:04:50AM +0100, grass at gevaerts.be wrote:
> On Sun, 30 Dec 2001, Markus Neteler wrote:
> > Hi,
> > below sound very much like the "i.rectify-doesn't-write-the-file-completely"
> > bug.
> > Frank, can you verify that the hard drive *always* provides enough
> > space? At time i.rectify silently dies if the drive is full.
> > However, there might be other bugs in certain cases...
> I think I found it.
> The cellhd file for the rectified image was :
> proj:       3
> zone:       0
> north:      1:57:21.412104N
> south:      20:22:26.088173S
> east:       36:24:44.4E
> west:       23:25:44.4E
> cols:       1558
> rows:       2680
> e-w resol:  0:00:30
> n-s resol:  0:00:29.995336
> format:     0
> compressed: 1
> After I changed 'format' from 0 to 1 everything seems to wrok fine. So
> i.rectify apparently sets this wrong (at least in some cases).
Wow - excellent. Now we have to identify the problem in i.rectify.
A candidate is
src/imagery/i.rectify2/rectify.c
   G_set_cell_format (cellhd.format);
Mhhh, why is this function needed here?
Happy new year to everybody!
 Markus
> > Markus
> > On Sat, Dec 29, 2001 at 06:34:33PM +0100, grass at gevaerts.be wrote:
> > > Hi,
> > > I am using Grass 5.0pre2 on a linux system (debian unstable , kernel
> > > 2.4.16, gcc 2.95.4)
> > > After importing an image with r.in.tiff and rectifying it with i.rectify
> > > (after doing all intermediate steps), every tool I tried coredumps on the
> > > resulting raster (d.rast,r.support,r.compress,nviz,...)
> > > The backtrace is :
> > > (gdb) bt
> > > #0  0x400c3c3b in free () from /lib/libc.so.6
> > > #1  0x400c3ac3 in free () from /lib/libc.so.6
> > > #2  0x08050a9b in close_old (fd=6) at closecell.c:76
> > > #3  0x080508d6 in G_close_cell (fd=6) at closecell.c:44
> > > #4  0x0804a595 in cell_draw (name=0x809a8d8 "meren",
> > >     mapset=0x809aa28 "PERMANENT", colors=0xbffff8f8, overlay=0, invert=0,
> > >     data_type=0) at display.c:134
> > > #5  0x0804a34d in display (name=0x809a8d8 "meren",
> > >     mapset=0x809aa28 "PERMANENT", overlay=0, bg=0x0, data_type=0,
> > > invert=0)
> > >     at display.c:59
> > > #6  0x08049ba1 in main (argc=2, argv=0xbffffb74) at main.c:110
> > > #7  0x4006e65f in __libc_start_main () from /lib/libc.so.6
> > > (for d.rast, the others are identical from G_close_cell up, except that
> > > nviz crashes on line 75 in closecell.c)
> > > line 75 is :  free (FCB.row_ptr);
> > > line 76 is :  free (FCB.col_map);
> > > FCB seems to be :
> > > (gdb) print  G__.fileinfo[fd]
> > > $1 = {open_mode = 1, cellhd = {format = 0, compressed = 1, rows = 2680,
> > >     cols = 1558, proj = 3, zone = 0, ew_res = 0.0083333333333333367,
> > >     ns_res = 0.0083320377567371474, north = 1.9559478066666667,
> > >     south = -20.373913381388888, east = 36.412333333333336,
> > >     west = 23.428999999999998}, reclass = {name = '\000' <repeats 49
> > > times>,
> > >     mapset = '\000' <repeats 49 times>, type = 0, num = 0, min = 0, max =
> > > 0,
> > >     table = 0x0}, statf = {node = 0x0, tlen = 0, N = 0, curp = 0,
> > >     null_data_count = 0, curoffset = 0}, range = {min = 0, max = 0,
> > >     first_time = 0}, fp_range = {min = 0, max = 0, first_time = 0},
> > >   compression_bits = 0, want_histogram = 0, reclass_flag = 0,
> > >   row_ptr = 0x8093850, col_map = 0x8096238, C1 = 1, C2 = 0.5, cur_row =2679,
> > >   null_cur_row = -1, cur_nbytes = 1, data = 0x8097a98 "", nbytes = 1,
> > >   map_type = 0, temp_name = 0x0, null_temp_name = 0x0, null_file_exists =
> > > 1,
> > >   name = 0x808da68 "meren", mapset = 0x808da78 "PERMANENT", io_error = 0,
> > >   xdrstream = {x_op = XDR_ENCODE, x_ops = 0x0, x_public = 0x0,
> > >     x_private = 0x0, x_base = 0x0, x_handy = 0}, NULL_ROWS = {
> > >     0x8093148 "HÍ\032 at HÍ\032@", 'ÿ' <repeats 184 times>, "È",
> > >     0x8093210 'ÿ' <repeats 192 times>, "\220\001",
> > >     0x80932d8 'ÿ' <repeats 192 times>, "X\002",
> > >     0x80933a0 'ÿ' <repeats 192 times>, " \003",
> > >     0x8093468 'ÿ' <repeats 192 times>, "è\003",
> > >     0x8093530 'ÿ' <repeats 192 times>, "°\004",
> > >     0x80935f8 'ÿ' <repeats 192 times>, "x\005",
> > >   null_work_buf = 0x8093788 'ÿ' <repeats 192 times>, "\b\a",
> > >   min_null_row = 2672, quant = {truncate_only = 0, round_only = 0,
> > >     defaultDRuleSet = 0, defaultCRuleSet = 0, infiniteLeftSet = 0,
> > >     infiniteRightSet = 0, cRangeSet = 0, maxNofRules = 0, nofRules = 0,
> > >     defaultDMin = 0, defaultDMax = 0, defaultCMin = 0, defaultCMax = 0,
> > >     infiniteDLeft = 0, infiniteDRight = 0, infiniteCLeft = 0,
> > >     infiniteCRight = 0, dMin = 0, dMax = 0, cMin = 0, cMax = 0, table =
> > > 0x0,
> > >     fp_lookup = {vals = 0x0, rules = 0x0, nalloc = 0, active = 0,
> > >       inf_dmin = 0, inf_dmax = 0, inf_min = 0, inf_max = 0}}}
> > > Is this a known problem, or am I doing something wrong ?
> > > Please ask if you need more info
> > > Frank
> > > HI! I'm a .signature virus! cp me into your .signature file to help me spread!
> > grass5 mailing list
> > grass5 at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass5
> grass5 mailing list
