[GRASS5] v.digit problems
Eric G. Miller
egm2 at jps.net
Mon Feb 26 21:14:37 EST 2001
On Mon, Feb 26, 2001 at 01:17:41PM +0000, Markus Neteler wrote:
> Hi all,
> when using "widen view" in (un)zoom in v.digit, and
> having the GRASS monitor *partly* outside the screen,
> the monitor isn't refreshed any more. This leads to
> various overlayed vector pictures resulting from the
> different zoom operation. If you move back the monitor
> fully into the screen, refresh is back o.k.
> Just to notify you (probably Eric),
Yep, I can confirm. Undoubtedly the result of a blocked read. I tried
to modify the way SWITCHER handles reads, but there seem to be a dozen
different pathways to read/write on the communications channel, all
making for a god awful mess. Most likely it's blocking in read1().
Unfortunately, handling the blocked read is not straight forward. I'll
try to look at it again, when I can.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
