[GRASS5] GRASS release critical bugs list
Markus Neteler
neteler at geog.uni-hannover.de
Sat Feb 24 12:43:24 EST 2001
On Wed, Feb 21, 2001 at 09:48:48AM -0600, Helena wrote:
> Markus,
> I checked the bugs and these are my comments:
> >RC]r.los:
> >r.los seems to work perfectly if the elevation data is UTM. But if the
> elevation data is latitude-longitude, like most of my elevation data, the
> output map looks like a hollow footprint`k
> I don't think that this one is RC, there are more modules which do not
> support lat/long (e.g. s.surf.rst), so the manual should just say that
> this command does not support lat/long (untill somebody so desperately
> needs it that he/she will do it). You can always project your DEM to UTM
> or other projection and run r.los. This is lack of capability rather than
> RC bug.
That's right. I have added a test for lat/long, in this case r.los will
simply exit with a message.
Regards
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
