[GRASS5] Looking for ncurses code
Eric G. Miller
egm2 at jps.net
Fri Feb 23 22:45:05 EST 2001
On Fri, Feb 23, 2001 at 09:44:33AM -0800, Rich Shepard wrote:
> On Fri, 23 Feb 2001, Markus Neteler wrote:
> > You can see CLI at work in src/raster/r.agnps50/ if you need an
> > example.
> Again, thanks, Markus.
> I've grep'd the files in src/libes/vask/ and haven't found the names of
> the variables used to store the input (GISDBASE. location and mapset). Is
> there any guide in the programmer's manual to the organization of the start
> up code and the user interface? I don't recall seeing that the last time I
> looked.
The vask library is just a simplified wrapper for curses. The GISDBASE,
LOCATION and MAPSET are written to the ~/.grassrc5 file. If you're
interested in the session start-up code, have a look in
src/general/init/, which among other things sets the environment
variables above. Also good to poke around src/libes/gis/ to see how
many things are handled regarding database management, I/O, etc... Don't
rely on the Programming manual. It's helpful, but doesn't document a
lot of stuff (some things just aren't documented).
> I'll look at the tcl/tk code, too, and see if I can find these variable
> names there.
It gets them from the environment...
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
