[GRASS5] GRASS 5 and sockets: default?
Markus Neteler
neteler at geog.uni-hannover.de
Wed Feb 21 05:14:06 EST 2001
Hi Eric and Justin,
On Wed, Feb 21, 2001 at 01:59:27PM +0700, Justin Hickey wrote:
> Hi Markus, Eric
> Markus Neteler wrote:
> > > Well, for some reason I see tcltkgrass has a "d.mon start=$mon"
> > > followed by a "d.mon stop=$mon". I'm not sure why it's set-up like
> > > this...
> > > In src/tcltkgrass/main/gui.tcl:
> > > proc stop_monitors {} {
> > > foreach monitor [search_xdrivers] {
> > > exec d.mon start=$monitor >& /dev/null
> > > exec d.mon stop=$monitor >& /dev/null
> > > script_add "d.mon start=$monitor >& /dev/null" "cmd"
> > > script_add "d.mon stop=$monitor >& /dev/null" "cmd"
> > > Since it's run without a controlling tty, and the monitor is already
> > > running when d.mon is asked to start it again, you get an error
> > > message in your mailbox from d.mon...
> > > Anybody want to hit me with a clue stick as to why tcltkgrass would
> > > first try to start the monitor? only to kill it?
> > Eric,
> > just guessing:
> > In case you have running x3 only, the "for" loop would try to
> > close x0 (crash), x1 (crash), x2 (crash), x3 (o.k.) etc.
> > As d.mon -L is running now, we could use this to find the
> > running monitors. d.mon -L was failing with fifos (at least on Linux).
> Well I looked at the code and the search_xdrivers procedures is a list
> of monitors that are currently open, based on a call to "xlsclients -l".
> Thus, this list should only contain monitors that are open, unless for
> some reason, the connection (socket, fifo, ipc) was closed and the
> window was left open. Therefore, I don't see any reason for the start
> commands and I think it should be changed to
Nice idea. Works for me with sockets.
> This seems to work on my machine using sockets. The "close all x
> monitors" option for quit worked well, but the
> Config->Monitors->stop->x0 menu option seemed to take a long time.
Here as well.
>Of course this change is also necessary for the stop_monitor procedure.
> Anyway, what do you think?
Eric, I have the problem that the sockets are freed:
d.mon x4
Can't bind to socket for monitor <x4>. Already in use?
Socket is already in use or not accepting connections.
Use d.mon to select a monitor
Problem selecting x4. Will try once more
d.mon stop=x4
Error - Monitor 'x4' was not running
How to get them back? It seems to be related to my tcltkgrass experiments.
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
