[GRASS5] Latest release of ProgManGrass
Markus Neteler
neteler at geog.uni-hannover.de
Wed Feb 21 04:55:52 EST 2001
On Wed, Feb 21, 2001 at 07:34:57PM +1100, John Reid wrote:
> Hi listers,
> Any answers to this might avoid confusing someone in the future. When using the
> www interface to cvs (http://freegis.org/cgi-bin/viewcvs.cgi/), the
> progmangrass50 directory (module? not sure of correct cvs terminology) is not
> visible. Could this be changed to show all the available modules?
This decision is left to the CVS admin (hi Bernhard).
> I had the same problem as Andrea a few days ago. The web interface to cvs was
> the first place I looked - it seems a logical starting point to find out what is
> available in cvs.
> cheers,
> John
Sounds reasonable to me.
Kind regards
Markus
> Markus Neteler wrote:
> > On Tue, Feb 20, 2001 at 12:34:56PM +0100, Andrea Aime wrote:
> > > Hy everybody,
> > > I would like to download the latest version of Progmangrass5, I've
> > > seen that I should search for it on CVS. I can't find it... where
> > > is it? (I used web CVS access, not command line one. I've also taken
> > > a look in a CVS snapshot I downloaded, but I can't find it).
> > > Anyone can help me?
> > Hi Andrea,
> > see the SUBMITTING file in source code:
> > 1. Get the latest GRASS 5 Programmer's Manual here:
> > http://www.geog.uni-hannover.de/grass/grassdevel.html#prog
> > or (better) grab it from GRASS CVS server (Latex):
> > cvs -z3 co progmangrass50
> > It's not in the cvs snapshot because it's a "parallel" directory
> > to "grass"
> > Hope this helps,
> > Markus
> john reid e-mail john_reid at uow.edu.au
> technical officer room G02, building 41
> school of geosciences phone +61 02 4221 3963
> university of wollongong fax +61 02 4221 4250
> uproot your questions from their ground and the dangling roots will be
> seen. more questions!
> -mentat zensufi
> apply standard disclaimers as desired...
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
