[GRASS5] Latest release of ProgManGrass
John Reid
jgreid at uow.edu.au
Wed Feb 21 03:34:57 EST 2001
Hi listers,
Any answers to this might avoid confusing someone in the future. When using the
www interface to cvs (http://freegis.org/cgi-bin/viewcvs.cgi/), the
progmangrass50 directory (module? not sure of correct cvs terminology) is not
visible. Could this be changed to show all the available modules?
I had the same problem as Andrea a few days ago. The web interface to cvs was
the first place I looked - it seems a logical starting point to find out what is
available in cvs.
cheers,
John
Markus Neteler wrote:
> On Tue, Feb 20, 2001 at 12:34:56PM +0100, Andrea Aime wrote:
> > Hy everybody,
> > I would like to download the latest version of Progmangrass5, I've
> > seen that I should search for it on CVS. I can't find it... where
> > is it? (I used web CVS access, not command line one. I've also taken
> > a look in a CVS snapshot I downloaded, but I can't find it).
> > Anyone can help me?
> Hi Andrea,
> see the SUBMITTING file in source code:
> 1. Get the latest GRASS 5 Programmer's Manual here:
> http://www.geog.uni-hannover.de/grass/grassdevel.html#prog
> or (better) grab it from GRASS CVS server (Latex):
> cvs -z3 co progmangrass50
> It's not in the cvs snapshot because it's a "parallel" directory
> to "grass"
> Hope this helps,
> Markus
john reid e-mail john_reid at uow.edu.au
technical officer room G02, building 41
school of geosciences phone +61 02 4221 3963
university of wollongong fax +61 02 4221 4250
uproot your questions from their ground and the dangling roots will be
seen. more questions!
-mentat zensufi
apply standard disclaimers as desired...
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
