[GRASS5] February 19, 2001 Cygwin build
John Huddleston
jhudd at lamar.colostate.edu
Tue Feb 20 14:49:45 EST 2001
Markus, (Anyone)
It was configured --with-ipc
Do you have a recommendation for configure for Cygwin?
John
----- Original Message -----
From: "Markus Neteler" <neteler at geog.uni-hannover.de>
To: <grass5 at geog.uni-hannover.de>
Sent: Tuesday, February 20, 2001 2:18 AM
Subject: Re: [GRASS5] February 19, 2001 Cygwin build
> John,
> On Mon, Feb 19, 2001 at 03:00:36PM -0700, John Huddleston wrote:
> > Markus, (List)
> > I have built a Cygwin version using source code checked
> > out on February 19, 2001. As with all of the builds, the
> > source is checked out into a new directory, a configure
> > is done, and the build is started.
> thanks for the new build. Does it use IPC or already sockets?
> > Since the builds have been very stable, that is, no hand
> > tweaking to make them build, I have been building and
> > trying other software such as tcl, odbc, and postgresql.
> > I tried the tcltkgrass and the $window number is not
> > defined. It fails on line 1158 of gui.tcl; can anyone
> > give me some insight as to why it fails?
> Sorry, no idea. Perhaps someone else?
> > Markus, the grass5-20010219.zip is in the incoming
> > directory on your ftp server. Please update the binary
> > http://www.geog.uni-hannover.de/grass/grass5/binary/windows_cygnus/
> Yep, it's online now.
> Thanks again,
> Markus
> If you want to unsubscribe from GRASS Development Team mailing list write
to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
If you want to unsubscribe from GRASS Development Team mailing list write to:
