[GRASS5] Sockets code
Markus Neteler
neteler at geog.uni-hannover.de
Sun Feb 18 10:28:28 EST 2001
On Sat, Feb 17, 2001 at 07:45:41AM -0700, John Huddleston wrote:
> Malcolm, (Eric?)
> Did you commit the changes to the cvs?
> John Huddleston
Hi John,
yes, Eric submitted to CVS.
Markus
> ----- Original Message -----
> From: "Malcolm Blue" <mblue at nb.sympatico.ca>
> To: "grass5 Developers List" <grass5 at geog.uni-hannover.de>
> Sent: Wednesday, February 14, 2001 12:27 AM
> Subject: [GRASS5] Sockets code
> > Eric,
> > I was able to get the new sockets code
> > running on Cygwin. To do this I had to
> > remove the '#ifndef __CYGWIN__' and
> > '#endif' statements sandwiching the
> > FONT and TEXT case statements in
> > SWITCHER.c, i.e.:
> > #ifndef __CYGWIN__
> > case FONT:
> > RECTEXT(text);
> > x = Font_get(text);
> > SEND(&x, sizeof(x));
> > break;
> > case TEXT:
> > RECTEXT(text);
> > Text(text);
> > break;
> > #endif
> > After that minor fix the sockets XDRIVER
> > seems to run on winNT/Cygwin. So far
> > I've just tested with some of the basic
> > d.* commands: d.mon, d.rast, d.vect,
> > d.histogram and d.erase, but once these
> > were working for the IPC version the
> > others worked as well.
> > Note that, we made these same changes to
> > the IPC version to run it.
> > Good work.
> > Malcolm
> > If you want to unsubscribe from GRASS Development Team mailing list write to:
> > minordomo at geog.uni-hannover.de with
> > subject 'unsubscribe grass5'
Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
