[GRASS5] Grass5 on Solaris
Eric G . Miller egm2 at jps.net
Thu Feb 15 21:29:54 EST 2001
On Thu, Feb 15, 2001 at 01:44:01PM -0400, Bob Covill wrote:
> Markus,
> You were close. It appears that flate.c was using the wrong config.h
> header. It was reading one from /usr/local/include, and therefore not
> getting any defines. If I manaully add the define HAVE_ZLIB_H to
> flate.c or add the full path to config.h it compiles cleanly.
What the heck puts a config.h in /usr/local/include ?  I'd think that
would break a lot of software builds as config.h is the de facto
standard name for defining "configure" output.
> The problem should be solvable by ensuring that the first "-I" flag
> looks in grass/src/include instead of picking other config.h files.
Yes, it should probably always be -I. -I$(SRC)/src/include <whatever>.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
