[GRASS5] Re: solaris
B. Byars Bruce_Byars at baylor.edu
Wed Feb 14 14:10:22 EST 2001
Hi Helena,
We're migrating to Solaris 8, but even its stable release has
network issues with DNS and DHCP.  Hopefully I can have
a Solaris build by tomorrw.  I'm updating the README's
and everything else as well.  I'll keep you posted on my progress.
Already worked out some of the library incompatabilities.  It
looks like when you do like we have here having both 32 and
64 bit OS's installed on the same machine, that's where the problems
arise.  I'm compiling a list of the offending files.  :-)
Other than Mesa, I'm using Tcl and Tk 8.3.  That should do
you nicely.  Just be sure you've got wish8.3 aliased to just
wish tho'.  Otherwise you'll run into problems.  I haven;t found
any Tcl widgets that aren;t downward compatible...yet.
Bruce
Helena Mitasova - staff wrote:
> >Solaris 7 32 bit has trouble finding zlib's located in
> >/usr/local/.  I've had to hard wire this to get a compile
> >to go.  Any quick fixes already or should I dig deeper
> Bruce,
> have you tried Solaris 8 - supposedly it is better than 7
> and it may not have a problem. I was told that Sun is
> encouraging users to switch from 7 to 8 as it has lots of
> fixes so it may be better to compile for for 8.
> Helena
> P.S. I haven't tried to install GRASS on the Sun that I have
> here yet but I plan to do it as soon as you post the binaries -
> I appreciate that mesa is there too - is there anything else
> that I need to install (I have tcltk)?
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
