[GRASS5] Sockets code
Eric G . Miller egm2 at jps.net
Wed Feb 14 03:19:19 EST 2001
On Wed, Feb 14, 2001 at 03:27:00AM -0400, Malcolm Blue wrote:
> Eric,
> I was able to get the new sockets code
> running on Cygwin.  To do this I had to
> remove the '#ifndef __CYGWIN__' and
> '#endif'  statements sandwiching the
> FONT and TEXT case statements in
> SWITCHER.c, i.e.:
Okay, then I can safely delete that cruft?  I've been trying to remove
some other unused junk as well (-Wall is helpful ;).
[snip]
> Note that, we made these same changes to
> the IPC version to run it.
Let me know if there other things needed.  Can you check if CygWin
supports nanosleep() (/usr/include/time.h probably)?  I'd like to use it
if I can, but I wonder about it's portability...
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
