[GRASS5] VASKLIB problem
William L. Baker
BakerWL at uwyo.edu
Mon Feb 12 17:53:13 EST 2001
Anyone had any problem with modules using VASKLIB?
My r.le.setup program worked fine under GRASS4.3.
Now after the V_ code, when the user has hit esc-return,
the screen freezes with the cursor in the upper-left corner.
The return values from the V_ code do get passed along
OK to subsequent code, but nothing happens because of
the screen freeze.
Could be a problem in my own code after the V_ section,
but I can't isolate the problem there.
In the old 4.3 version, the Gmakefile used VASK, but I
have fixed that up to just use VASKLIB as in the updated
Gmakefiles in beta 11.
Any ideas?
Bill Baker
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
