[GRASS5] Re: [GRASS-bugs] nviz2.2
Markus Neteler
neteler at geog.uni-hannover.de
Mon Feb 12 07:45:00 EST 2001
Hi developers,
On Mon, Feb 12, 2001 at 12:06:23PM +0000, uwe at danzeglocke.de wrote:
> Below is the result of your feedback form. It was submitted by
> (uwe at danzeglocke.de) on Monday, February 12, 2001 at 12:06:23
> subject: nviz2.2
> area: grass5beta11
> platform: Linux/Intel
> vendor: SuSe
> cputype: AMD (K6, ...)
> xwindows: Xfree 4.0.1
> windowsmanager: KDE 2.x
> tcltkver: tcl/tk 8.3
> grassserver: Hannover site
> grassversion: Linux/Intel binaries
> cvsyesno: -- select --
> compiler: -- select --
> bugreport: nviz2.2 fails to start:
> GRASS:~ > nviz2.2
> BUG IN DYNAMIC LINKER ld.so: dl-version.c: 210: _dl_check_map_versions: Assertion `needed != ((void *)0)' failed!
> child process exited abnormally
> while executing
> "exec /usr/local/grass5/etc/nviz2.2/NVWISH2.2 -f /usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdout"
> ("eval" body line 1)
> invoked from within
> "eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $CMD -name NVIZ >&@stdout
> (file "/usr/local/grass5/bin/nviz2.2" line 92)
> name: Uwe Danzeglocke
currently there is above problem with the GRASS 5b11 Linux binaries
on some platforms. I have no idea how to overcome it. There must be some
library version conflict. On my platform (even Suse), it works well.
Comments would be appreciated,
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
