[GRASS5] new directory structure?
Eric G . Miller egm2 at jps.net
Sat Feb 10 18:37:08 EST 2001
On Sat, Feb 10, 2001 at 03:36:18PM -0700, bakerwl wrote:
> Hello,
> After installing beta11, I'm a little confused about the new
> directory structure.  Maybe I did something wrong, or maybe
> one of the "make clean" variations fixes this.
> It looks like I get identical copies of the /bin /bwidget /documents
> /driver /etc ...and so on directories in both:
> /usr/local/grass5
> /usr/local/grass5/grass5.0beta11_src/dist.i686-pc-linux-gnu/
> I just put the *.tar.gz in /usr/local/grass5 and unzipped/untarred
> then went into grass5.0beta11_src and ran:
> ./configure
> make
> make install
Yes, this is "correct".  Essentially the set-up builds everything into
$(SRC)/dist.$(ARCH).  "make install" basically copies this to the final
destination.  Given the way gmake5 and the sources are set-up, this was
a work around to allow a full build to be done (as any old user) and
then the install to be done as a priveledged user.
It probably would be better if each Gmakefile built its final modules in
OBJ.$(ARCH) and then there was an "install" target, but I don't think
the gmake5 setup will work this way (not sure).  That's probably how
grass5.1 will work.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
