[GRASS5] Zlib not found on ./configure?
bakerwl
bakerwl at uwyo.edu
Sat Feb 10 16:51:35 EST 2001
Thanks Eric, the XDRLIB fixed the second problem fine.
Bill B.
"Eric G . Miller" wrote:
> On Sat, Feb 10, 2001 at 01:06:18PM -0700, bakerwl wrote:
> > I think there was discussion of this problem, but I've lost the
> > emails...
> > ./configure of beta11 leads to:
> > checking GL/gl.h and GL/GLmMDrawA.h...configure:
> > warning: ***Did not find GL/GLwMDrawA.h
> Only needed for r3.showdspf.openGL (You'll need Mesa or OpenGL widgets
> which are separate from the base Mesa or OpenGL stuff).
> > then when I later try to compile one of my r.le modules
> > I get errors in G_zlib_compress and G_zlib_expand
> > e.g., undefined reference to 'deflateInit_' etc.
> > This is on Mandrake 7.2 on Intel.
> Make sure the Gmakefile has $(XDRLIB) in the $(CC) line. If it does
> already, then also add $(ZLIB), though possibly your gmake5 is not up
> to date. Looks like a linker problem (need to have -lz flag and,
> obviously, libz).
> Eric G. Miller <egm2 at jps.net>
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
