[GRASS5] Re: [GRASSLIST:1423] r.water.fea tutorial
Rich Shepard rshepard at appl-ecosys.com
Tue Feb 6 08:31:10 EST 2001
On Tue, 6 Feb 2001, Markus Neteler wrote:
> You can also generate PDF from it with ps2pdf which is distributed with
> ghostscript (probably already on your machine). Then acroread will work.
  FWIW, ps2pdf with ghostscript through 5.5 is of very poor quality. Upgrade
ghostscript to 6.x and the ps2pdf works much better, by several orders of
magnitude.
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
              Making environmentally-responsible mining happen. (SM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
 + 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
