[GRASS5] nviz-bug]
Bob Covill
bcovill at tekmap.ns.ca
Mon Feb 5 12:18:54 EST 2001
Markus Neteler wrote:
> > > Bob,
> > > using a lat/long dataset your proposed change leads to the opposite effect:
> > > The surface is rather dark then. If switching back to the current CVS
> > > version it's quite good (little dark only, but adjustable).
> > > Maybe the use of USE_GL_NORMALIZE must be dependent on the projection?
> > > Markus
> > Markus,
> > Unfortunately, I have not had a chance to test the change on alot of datasets.
> > I would suggest also removing the changes in GS2.c that I made a while back as a temp
> > fix for Lat Long databases. This is the section where the Longdim variable is
> > calculated. Just revert it to the old calc method and give it a try.
> > Let me know if this helps.
> Bob,
> obviously not... I reverted to GS2.c rev.1.3 and commented the
> USE_GL_NORMALIZE in gs_norm.c, rebuilt the lib and NVIZ: All black
> then.
> Sorry for no better news,
> Markus
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Markus,
Well it was worth a try. There is one other routine that I was playing with a while back
for calculating normals with Lat Long databases. I will give that a try later on and let
you know if it works.
Bob Covill
Tekmap Consulting
P.O. Box 2016
Fall River, NS
Canada
B2T 1K6
