[GRASS5] Todo
Markus Neteler
neteler at geog.uni-hannover.de
Sun Feb 4 15:46:29 EST 2001
On Sun, Feb 04, 2001 at 11:57:45AM -0800, Jeshua Lacock wrote:
> On Sunday, February 4, 2001, at 11:27 AM, Eric G . Miller wrote:
> > > I checked out the code yesterday (not an update, a cvs co)
> > > and it failed because it could not change directory into a TODO
> > > directory. In Unix we can have upper and lower case
> > > distinctions, not so in Cygwin. Would somebody please
> > > check to see if there is a "todo" directory, if so, remove
> > > the todo file?
> > Is this lack of case sensitivity just in the make environment? I've
> > been using CygWin a little at work, and it seems to respect case (maybe
> > it's different on NTFS vs. the various FAT filesystems?).
> Greetings,
> I just got this TODO, too here in Mac OS X land.
> > cvs -z3 co -r "release_grass5beta11_4_february_2001" grass
> snip...
> unrecognized request `TODO/'
> I don't know what's case-sensitive and until the recent INSTALL problem I was not aware of it's case-sensitivity.
> My grass directory does indeed have a todo directory. Should I move it?
> It has a display_driver directory in it.
Hi Jeshua,
you are currently not using "cvs update" but "cvs checkout".
You will
- either "cvs up -dP" the current cvs tree
- or "cvs -z3 co -r "release_grass5beta11_4_february_2001" grass" a new
grass sources tree into an *empty* directory.
A mixture will cause above problems.
Currently
cvs up -dP todo
cvs up -dP
in your existing tree will do the job as so far no new
changes are uploaded.
Hope this helps,
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
