[GRASS5] Todo
Eric G . Miller egm2 at jps.net
Sun Feb 4 14:27:20 EST 2001
On Sun, Feb 04, 2001 at 06:14:55AM -0700, John Huddleston wrote:
> Grass list,
> I checked out the code yesterday (not an update, a cvs co)
> and it failed because it could not change directory into a TODO
> directory.   In Unix we can have upper and lower case
> distinctions, not so in Cygwin.  Would somebody please
> check to see if there is a "todo" directory, if so, remove
> the todo file?
Is this lack of case sensitivity just in the make environment?  I've
been using CygWin a little at work, and it seems to respect case (maybe
it's different on NTFS vs. the various FAT filesystems?).
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
