[GRASS5] Error in fresh compile (ipc)
Malcolm Blue
mblue at nb.sympatico.ca
Tue Jan 30 20:34:46 EST 2001
Justin,
Re #3. See Huidae's message. He had trouble adding the renamed file to the
src/scripts/shells directory. It looks like this has been fixed. I've just
downloaded but haven't tested yet.
Last night I ran into this problem and sent a message to Huidae off line, which
he fixed almost immediately - by renaming the script file. I had already tested
his script file and it ran correctly, it just needed to be renamed.
Update the src/scripts/shells directory and this should be resolved.
Malcolm
Justin Hickey wrote:
> Hello all
> I just did a fresh compile on our SGI system and had three errors.
> 1. r.cn - missing LDFLAGS in command line - fixed
> 2. r.in.gdal - same as always
> 3. The following messages at the end of make
> src/scripts/shells/create_ipcs.sh - No such file or directory
> Cannot access
> /usr/people/jhickey/temp/grass/dist.mips-sgi-irix6.5/dev/create_ipcs.sh:
> No idea how to fix 3. Just a report.
> Sincerely,
> Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
> High Performance Computing Center
> National Electronics and Computer Technology Center (NECTEC)
> Bangkok, Thailand
> People who think they know everything are very irritating to those
> of us who do. ---Anonymous
> Jazz and Trek Rule!!!
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
