[GRASS5] Configure Warning
Jeshua Lacock
jeshua at SierraMaps.com
Tue Jan 30 01:10:56 EST 2001
On Monday, January 29, 2001, at 09:17 PM, Eric G . Miller wrote:
> On Mon, Jan 29, 2001 at 07:05:01PM -0800, Jeshua Lacock wrote:
> > Hi Eric,
> > FYI, this snip from my config output seems odd to me:
> > checking Tcl include dirs... -I/usr/local/include
> > checking Tk include dirs... -I/usr/local/include
> > checking Tcl/Tk library dirs... -L/usr/local/lib
> > checking for Tk_MainWindow in -ltk8.0... no
> > configure: warning: *** Failed to find Tcl/Tk libraries
> > It finds the Tcl/Tk libs, but reports it doesn't.
> An unending burr in my britches... ;)
> I'm guessing you get that with a clean slate (i.e. does removing
> config.cache and re-running ./configure make a difference) ?
Eric, yes, you are correct. Removing config.cache and re-running ./configure does not make a difference.
> Probably another library is needed for 'ld' in the test script that is
> generated. Is Tk tied into the native GUI on OS X? or is it tied to
> XFree86? Could make a difference...
> Maybe:
> $ ldd /usr/lib/libtk8.0.so
> will tell you (won't work on ar archives [*.a]).
Mmm, I have a /usr/lib/libtk8.0.a, not /usr/lib/libtk8.0.so. And I do not have a "ldd" program. I tired:
$ ld /usr/lib/libtk8.0.a
And it reports: "ld: no object files loaded"
But as you pointed out, it won't work on archives.
Regards,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
