[GRASS5] Layered XDRIVER2 uploaded into /todo section
Markus Neteler
neteler at geog.uni-hannover.de
Sat Jan 27 16:30:15 EST 2001
Hi again,
to avoid that the code gets lost: I have uploaded the
layered XDRIVER2 into a new /todo section in CVS
(cvs up -dP)
This directory contains
- a new layered XDRIVER2 (fifo)
- a new R_driver2()
- display modules updated to have a new r:g:b color parameter
- d.layers to allow layer management in GRASS Monitor
- the communication between Markus and Pierre on this issue
The diffs are against GRASS 5beta7
Everything written by Pierre de Mouveaux <pmx at audiovu.com>
(unfortunately currently offline from GRASS development)
Pierre's idea was to implement a XDRIVER supporting maps as
layers (to individually switch them on and off within a GUI).
The d.layers module demonstrates how it works (it does!).
Additionally a new display parameter to control display colors
by r:g:b values have been implemented.
Find it all in todo/
Regards
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
