[GRASS5] XDRIVER problems
John Huddleston
jhudd at lamar.colostate.edu
Sat Jan 27 09:54:38 EST 2001
Thank you Markus, Huidae, and Malcolm,
From now on I will concentrate on building it.
John Huddleston
----- Original Message -----
From: "Markus Neteler" <neteler at geog.uni-hannover.de>
To: <grass5 at geog.uni-hannover.de>
Sent: Friday, January 26, 2001 11:23 AM
Subject: Re: [GRASS5] XDRIVER problems
<snip>
> No, Huidae just implemented two new parameters into "configure":
> --with-ipc use ipc XDriver instead of fifo (for Cygwin)
> --with-fifo use fifo XDriver instead of ipc (default)
> Huidae - good idea, thanks!
> So it shouldn't bother you any more and the IPC code can be
> savely developed in parallel.
> Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
