[GRASS5] r.contour crashes if step=0.5
Markus Neteler
neteler at geog.uni-hannover.de
Sat Jan 27 08:26:25 EST 2001
Roger,
On Sat, Jan 27, 2001 at 01:38:02PM +0100, Roger Bivand wrote:
> On Sat, 27 Jan 2001, Markus Neteler wrote:
> > > > Hi developers,
> > > > r.contour crashes if step=0.5... Floating point exception.
> > > > I actually cannot see the problem. The offending line is a macro:
> > > > dmax = (max->answer) ? atof (max->answer) : zmax - (int)zmax%(int)dstep;
> > > > dstep contains 0.5, zmax is determined my the program zmax=7.1231 here).
> > > It's the (int) cast on dstep, which becomes integer 0, and which gives a
> > > NaN when used for division. For this code to work, dstep must be >= 1. It
> > > looks a bit cludgy too.
> > I see. But in my case I have a map with pH values ranging from 5.5 to
> > 7.3. So setting "step" to 1 doesn't produce exciting contours.
> > Even step is a double. Se we might need to change this line (and the next
> > in main.c of r.contours)?
> Sorry to "fake" this in R, but it's the integer casts that cause the
> problem:
> > dstep <- 0.5
> > max <- NULL
> > min <- NULL
> > zmax <- 7.3
> > zmin <- 5.5
> > zmax %% dstep
> [1] 0.3
> > zmin %% dstep
> [1] 0
> > dmax <- ifelse(!is.null(max), as.numeric(max),
> zmax - (as.integer(zmax) %% as.integer(dstep)))
> > dmax
> [1] NA
> zmax - (zmax %% dstep))
> > dmax
> [1] 7
> > dmin <- ifelse(!is.null(min), as.numeric(min),
> ifelse(as.integer(zmin) %% as.integer(dstep),
> zmin - (as.integer(zmin) %% as.integer(dstep)), zmin))
> > dmin
> [1] NA
> ifelse(zmin %% dstep, zmin - (zmin %% dstep), zmin))
> > dmin
> [1] 5.5
> If you set max and min for your contours, you wouldn't hit the bug, nor if
> you set the levels manually. Whether removing the casts is OK later on is
> another question, but it looks as though there are no more (int) casts,
> so I'd take out the casts in the assignments to dmax and dmin.
It seems that C behaves differently than "R".
The compiler doesn't accept modulo with doubles:
gcc -g -O2 -I/home/neteler/ggg/src/include -c main.c -o
OBJ.i686-pc-linux-gnu/main.o
main.c: In function 'getlevels':
main.c:233: invalid operands to binary %
main.c:234: invalid operands to binary %
main.c:235: invalid operands to binary %
You are right, if I add max= and min= the problem of course disappears.
Maybe we can get rid of this macro? To be honest, I just don't get
the idea of it. Do we need it (like that)?
Thanks for looking into this,
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
