[GRASS5] 5beta11pre1 configure failure on mac osx pb
Bernhard Reiter bernhard at intevation.de
Thu Jan 25 12:02:58 EST 2001
On Thu, Jan 25, 2001 at 05:21:26PM +0000, Markus Neteler wrote:
> On Thu, Jan 25, 2001 at 10:31:22AM -0600, andy agena wrote:
> > Is there any chance to compile the mathlib extra with c-compiler?
The question is, do you need to have -lm for math functions to work.
If you do not need the math library and still have functions like
sin() in the standard libraries for your system, you will be fine
with just removing the "-lm" options.
You should check were there is a libm* on your system somewhere.
You might be able to give the location to the configure script:
	LDFLAGS=-L/your/path/to/libm.so
> Probably it is just in a place where configure doesn't look.
> > > checking for gcc... no
> > checking for cc... cc
> Aha!
So everything is fine here.
IIRC cc on MacOSX actually is some sort of gcc. :)=
	Bernhard
Professional Service around Free Software                (intevation.net)
The FreeGIS Project                                         (freegis.org)
Association for a Free Informational Infrastructure            (ffii.org)
FSF Europe                                            	  (fsfeurope.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20010125/d1286cc4/attachment.bin
