[GRASS5] pre-test GRASS 5beta11pre1
Bernhard Reiter bernhard at intevation.de
Thu Jan 25 08:15:40 EST 2001
I am sorry, I have hit the wrong button sending this to the list.
(That's why it is in German. Here is a rough translation.)
Hello Markus,
thanks for the hard work.
Please make the Warning in the ftp directory more visable.
Didn't you plan to only release a source tarball, so that
only developer can really pretest?
On Thu, Jan 25, 2001 at 02:09:23PM +0100, Bernhard Reiter wrote:
> Hallo Markus,
> danke für die Arbeit:
> Bitte mach die Warnung in dem ftp Verzeichniss deutlicher!
> Wolltest Du nicht nur sourcen rausgeben, damit sich nur wirklich die
> Entwickler dran beteiligen?
> 	Bernhard
> On Thu, Jan 25, 2001 at 01:33:53PM +0000, Markus Neteler wrote:
> > time has come to publish beta11... :-)
> > http://www.geog.uni-hannover.de/grass/grass5/source/
> > I would like to ask you to test this tarball.
> > For Linux I will put out a binary tarball later this day.
> > NOTE:
> > The LZW-compression is removed from GRASS floating point
> > raster maps and G3D maps. Means: You have to convert
> > *all* FP and G3D maps. Plain CELL (Integer) maps are not affected.
> > See announcement and link to conversion tool here:
> > http://www.geog.uni-hannover.de/grass/announces/announce_lzw_removal.html
> > The conversion tool r.lzw2z runs pretty well now.
> > Thanks in advance for testing the new package,
> >  Markus
> > Markus Neteler *  University of Hannover
> > Institute of Physical Geography and Landscape Ecology
> > Schneiderberg 50 * D-30167 Hannover * Germany
> > Tel: ++49-(0)511-762-4494  Fax: -3984
> > If you want to unsubscribe from GRASS Development Team mailing list write to:
> > minordomo at geog.uni-hannover.de with
> > subject 'unsubscribe grass5'
> Professional Service around Free Software                (intevation.net)
> The FreeGIS Project                                         (freegis.org)
> Association for a Free Informational Infrastructure            (ffii.org)
> FSF Europe                                            	  (fsfeurope.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20010125/3f1490fc/attachment.bin
