[GRASS5] r.lzw2z updated...
Markus Neteler
neteler at geog.uni-hannover.de
Mon Jan 22 06:26:09 EST 2001
On Mon, Jan 22, 2001 at 02:35:34AM -0800, Eric G . Miller wrote:
> On Mon, Jan 22, 2001 at 09:36:25AM +0000, Markus Neteler wrote:
> > Eric,
> > just tested the updated module:
> > - no segfault any more, but
> > - I get this warning:
> > Processing aspect at helge ... Copying ... WARNING:
> > cell_misc/aspect/f_format file may be corrupted!
> > Processing slope at helge ... Copying ... WARNING: cell_misc/slope/f_format
> > There seems to be one bug left.
> Could you check what one of these files looks like? Maybe I need to
> handle a return value differently... Following conversion it should
> look like...
> type: float
> byte_order: xdr
> lzw_compression_bits: -1
> Prior to conversion, lzw_compression_bits should be between 9 and 20.
Mhhh, it is as above!
type: double
byte_order: xdr
> If it failed to update/write the file, the warning is correct. However,
> we don't want it to fail ;)
Yes, but what could be wrong?
Maybe it is o.k., just the warning is wrong.
Note: I didn't test the map (should have done). As I just
trashed my GRASs for recompilation, I cannot test this minute.
Update mail should follow in 10 minutes...
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
