[GRASS5] GRASS 5.0/5.1
Markus Neteler neteler at geog.uni-hannover.de
Fri Jan 19 08:38:36 EST 2001
Hi Justin,
got it! Now src/libes/g3d/ compiles well on CRAY (Linux, ...).
On Fri, Jan 19, 2001 at 06:27:45PM +0700, Justin Hickey wrote:
> Hi Markus
> Markus Neteler wrote:
> > Unfortunately there is one left with G3d on CRAY:
> > CC-147 cc: ERROR File = tilewrite.c, Line = 344
> >   Declaration is incompatible with
> >           "int G3d_putFloat(G3D_Map *, int, int, int, float)" (declared at
> >           line 499 of
> > "/home/t3e/fsn/nhdc/nhdcmark/grass/src/include/G3d.h").
> >   G3d_putFloat (map, x, y, z, value)
> Strange. Try changeing the declaration in tilewrite.c to the same as the
> include file. That is change
> int
>      G3D_Map *map;
>      int x, y, z;
>      float value;
> to the following
> int G3d_putFloat(G3D_Map *map, int x, int y, int z, float value)
> in tilewrite.c. Maybe the extra spacing is confused or something. Gotta
> go now.
That's it. It must be explicitly identical. CRAY cc is somewhat
paranoid.
So far on g3d - another chapter finished :-)
Yours
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
