[GRASS5] GRASS and backspace key
Markus Neteler
neteler at geog.uni-hannover.de
Thu Jan 18 13:15:26 EST 2001
On Thu, Jan 18, 2001 at 09:50:46AM -0700, Roger S. Miller wrote:
> On Thu, 18 Jan 2001, Markus Neteler wrote:
> > Hi all,
> > another annoying thing is that GRASS has some problems
> > with backspace key. If you enter a map name, it will
> > result to this:
> > VECTOR (DIGIT) FILENAME
> > Enter 'list' for a list of existing binary vector files
> > Hit RETURN to cancel request
> > > linien^H^H^H^H^H
> Try ctrl-backspace.
Unfortunately no hope...
> list^H^H^H^H^H
Ah funny:
r.in.gdal
OPTION: Bin raster file to be imported
key: input
required: YES
enter option > li
Here it is o.k. So the bug is limited to some? vector commands.
v.in.arc is o.k, v.support isn't.
Mhhh, perhaps an include file is missing in v.support? Strange thing!
> Just now I wasn't able to find a command that gave me that problem while
> running Linux and testing with the KDE desktop and fvwm2 window manager or
> with OS/2 with the ICE window manager. I've seen it (plenty) before and
> found it very frustrating. In all cases I've found if backspace doesn't
> work then ctrl-backspace does.
To conclude: At least on my Linux box it differs from command to command.
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
