[GRASS5] html to man conversion
Markus Neteler neteler at geog.uni-hannover.de
Wed Jan 17 04:24:05 EST 2001
On Wed, Jan 17, 2001 at 01:33:10PM +0700, Justin Hickey wrote:
> Hi Markus
> Markus Neteler wrote:
> > > It has to be changed since the -ot option is not supported on SGI
> > > machines. Perhaps we could use the getModTime function I added to
> > > src/general/init but then it would need to be compiled before the
> > > html conversion.
> > Hi Justin,
> > generally I don't see a problem to compile such tools. DO you
> > see a change to implement that?
> Are there other "tools" like this (ie separate programs or scripts that
> do not need to link to Grass)? If so we could group them together in a
> directory and compile them first. If not, we could move the getModTime.c
> file to the html directory and compile it there.
Hi Justin,
let's add
src/libes/tools
as later other tools might be added. It's better than mixing .c code
and .html.
Yours
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
