[GRASS5] grass5.0beta
Malcolm Blue
mblue at nb.sympatico.ca
Tue Jan 16 23:45:41 EST 2001
Justin,
If you gunzipped and untarred the beta 10 files correctly, they should
be in a directory called grass5.0beta10 directly under the directory
where you ran the tar command.
I assume that you followed the directions, and, substituting the beta
version number, did something like:
gunzip grass5.0beta10.tar.gz
tar -xvf grass5.0beta10.tar
This should have created a subdirectory called grass5.0beta10 . If you
typed these commands correctly you should see a long list of files being
extracted from the tar file - this takes a while.
Then, instead of the instruction listed in the README file:
cd grass5.0beta
just do
cd grass5.0beta10
Look at the INSTALL file in that directory for further information.
Malcolm
> Hello GRASS list:
> I am a new user hoping to learn the hydro simulation modeling capabilities of
> GRASS as well as its spatial stat components. I am attempting to install GRASS
> 5.0 beta10 to a RedHat7.0 linux box. I have gunzipped and tared the files and am
> ready to install, except I don't know where to run the ./configure and make
> install commands. I cannot find the grass5.0beta directory as documented. Where
> would this directory be? I assume in the same one as the other stuff. Anyways I
> would appreciate your help.
> Justin A Saarinen
> MS Candidate
> University of Florida Geography
> Gainesville, Florida USA
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20010117/c4514bcd/attachment.html
