[GRASS5] grass5.0beta
Justin Saarinen
jsaarine at ufl.edu
Tue Jan 16 16:36:01 EST 2001
Hello GRASS list:
I am a new user hoping to learn the hydro simulation modeling capabilities of
GRASS as well as its spatial stat components. I am attempting to install GRASS
5.0 beta10 to a RedHat7.0 linux box. I have gunzipped and tared the files and am
ready to install, except I don't know where to run the ./configure and make
install commands. I cannot find the grass5.0beta directory as documented. Where
would this directory be? I assume in the same one as the other stuff. Anyways I
would appreciate your help.
Justin A Saarinen
MS Candidate
University of Florida Geography
Gainesville, Florida USA
Markus Neteler wrote:
> On Mon, Jan 15, 2001 at 07:24:36PM +0700, Justin Hickey wrote:
> > Hi Markus
> > > > > Hi again,
> > > > > unfortunately another bug found on SUN in
> > > > > html/Gmakefile
> > > > > Copying html pages
> > > > > /bin/sh: test: unknown operator -ot
> > > > > I don't know the meaning of -ot, but it's not portable
> > > > > (Huidae, Michel?).
> > > > Uh ? excerpt from SunOS 5.7 man page of test
> > > > file1 -ot file2
> > > > True, if file1 exists and is older than file2.
> > > > BUT... [ or test are in /usr/ucb or /usr/bin for sun =>
> > > > $ if /usr/bin/test Lespinard.zip -ot Duclaux.zip ; then echo ok ; fi
> > > > ok
> > > > $ if /usr/ucb/test Lespinard.zip -ot Duclaux.zip ; then echo ok ; fi
> > > > Conclusion :
> > > > if test file1 -ot file2 ; then echo ok ; fi # doesn't work
> > > > if /bin/test file1 -ot file2 ; then echo ok ; fi # works !
> > > > Silly mixing of old SunOS and new Solaris versions... !
> > > I have checked that. And I have renamed
> > > /usr/ucb/test
> > > to
> > > /usr/ucb/test_old
> > > .. but above problem is still there.
> > > The "-ot" test occurs from
> > > html/Gmakefile:
> > > if [ ! -f $$f -o $$f -ot $$h ]
> > > So "test" is not called directly. How can we fix this?
> > It has to be changed since the -ot option is not supported on SGI
> > machines. Perhaps we could use the getModTime function I added to
> > src/general/init but then it would need to be compiled before the html
> > conversion.
> Hi Justin,
> generally I don't see a problem to compile such tools. DO you
> see a change to implement that?
> Yours
> Markus
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
